14 bolt yoke won't come off, I want to drive my truck, please help!!!!!!
Discussion in 'The Garage' started by dawson444, Feb 13, 2004.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    14 bolt yoke won\'t come off, I want to drive my truck, please help!!!!!!
    I am trying to install my rear HAD shaft and I need to put on the 1410 yoke on the 14 bolt. I got the nut and washer off, but I can't get the yoke itself off.
    Please help!!!
    I have tried a 2 arm puller and it slips off. I then took some of the old bolts that went into the yoke and put a harmonic balancer puller on it and put a 3ft cheater bar on it, and it won't come off. I was afraid I was going to trip the puller like i did to my last one.
    I was thinking about pulling the pinion assembly out and put it on a press, but I was told that could mess up the gear setup.
    Please help!
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Re: 14 bolt yoke won\'t come off, I want to drive my truck, please help!!!!!!
    Hey Dawson when I replaced mine I took a BFH and tapped mine off. I hit and turned and it came off slowly. Give it a try and see what happons.
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    BFH and hit it like 43084308 times top and bottom then go side to side lol me and confedneck both were beating on mine he was hitting the bottom i was hitting the top /forums/images/graemlins/thinking.gif
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    ---UPDATE---
    I got it off, I hit it all ways for a while, the I put the straps on it, and put a steering wheel puller i had under the straps. Put the impact on the puller and it finally came off. Thanks for the tips!
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you replacing the crush sleeve?
  6. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    No.....?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Although I've replaced pinion yokes this way, it's really not the preferred method.
    Make sure to use plenty of red locktite and get a new pinion nut if you can find one.
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You dont have to replace the crush sleeve, as long as you retighten the pinion yoke just a tad bit tighter it will be fine. You also shouldnt have to put loctite on the pinion nut because they are torque withholding by design and I have never seen one come loose.
