14 bolt
Discussion in 'The Garage' started by 1979jimmy350, Jun 12, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I have a 14 bolt semi floater. What is envloved in swaping it in to my 79 Jimmy. What new parts will i need and what will need to be modifyed.
  2. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    well, that all depends on what you plan on doing and what you've got. we need more info. like what kind of t-case you've got, what you wanna do to/with the truck and so on.
    for basics though to just swap a 12bolt or 10bolt for a corp14 you'll need a conversion u-joint for your rear yolk. this will be one of those things where you take the u-joint off of your old drive shaft and the corp14 and then ask them to get you one behind the counter that mixes both of them. NAPA is great at doin this stuff. then there's you rear drive shaft length. if you haven't lifted your truck you may find that its too long. so lift it or shorten the rear shaft.
    hope this helps
    late
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    the conversion joint number is 447 at napa, i just got one today
