14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flblazer, Jul 11, 2001.
  1. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    will my brakes fit to it an my rims had no luck with this 10?
    mad crazy k5
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    You'll need 8 lug wheels, and before you buy a 14 bolt, look under your truck at the ebrake where the cables bolt to the frame. If you get a 14 bolt with the same type of cable then you should not have to change to a SF backing plate to use an ebrake.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</A>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Screw the E-brake, I cut that off a long time ago. One of my cheaper mods!
    Tim
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You have to know somebody that will inspect it with no e-brake.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
