14 bolt ?
Discussion in 'The Garage' started by Chrisblazzer89, Dec 17, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok so someone has offred me a 14 bolt for 75 bucks hs not sure of the gears in it. He does know it off of an 80s chevy pickup would this 14 bolt bolt right up to my 88 Blazer?
    I just sent him an email to find out if its a FF or SF hopefully he replys soon.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    If it's 3/4 ton it will.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if it is out of a 3/4 ton then everything will bolt up except the driveshaft. you will need a conversion u-joint. if it is 1 ton then the spring perches are off.
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yes it is a 3/4 yon axle does that mean its a SF? Thanx guys now for another ? is 75 bucks a good deal for a 14 bolt
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    $75.00 is an excellent price for a 14ff, hell even if it was a 14sf still a good price. It could be either a 14ff or a 14sf in 3/4 ton truck.
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    well its 8 lug if that helps. would that mean anything and could i get 6 lug axle shaft for it?
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Im guessing its a sf, but it could be ff. Easier to get rims then it is to try and make it 6 lug.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Or find a matching 10 bolt/d44 for the front.
  9. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    it is easy to tell the difference. a full float will have 6 bolts in the hub holding the axleshaft in. swapping the front to 8 lug is not that hard. everything from the balljoints out are interchangeable.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Fixed it for you. :D
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    14ff has hubs that stick out of the center of the wheel, 14SF looks like any other 1/2 ton rear axle.
    Ira
  12. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yeah fat fingers, alcohol, and tired don't mix.
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    ok here is wat he said ti try to help me find out if it was a FF or not it has 8 bolts on the axle sticking. 14 bolts on the cover.
    does this help any?
  14. sandawgk5
    Oct 28, 2003
    6,881
    Does the it look like this?
    With a cover like this?
    If yes then it is a 14FF
    Ira
