14 Bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dysphemism, Jan 4, 2002.
  1. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    I know this question has been asked to death but I'm going to go ahead and ask again. What 14 bolts will bolt right onto a 1986 GMC Jimmy? And also if I used the 2wd 14 bolt I know that something about them is different but I dont remember exactly what.
    PS - I AM NOW THE PROUD OWNER OF A DANA 60 FRONT
    Beefing up my truck broken part by broken part.
    1986 GMC Jimmy 9" lift, 38" swampers, and a sarcastic liscense plate holder.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You want any 3/4 ton 14 bolt. The only issues you may really run into are the parking brake cables.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I'm pretty sure any 4wd, 3/4 ton 14 bolt will bolt right in.
    If you get a 2wd 14bolt, I know the shock mounts are a lot lower, and can cause clearance problems. Don't know if there is anything else different about them.
    If you find a 4wd 1 ton 14 bolt, then the spring perches will have to be moved before it will fit on your Jimmy.
    Good luck, and congrats on the D60! I wish I could find one cheap enough to replace my D44 ..........
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    A 3/4 ton 4x4 14 bolt from the years 73 thru 87 should bolt in place- perches and shocks need NO modification. The e-brake I'm not too sure of. Yes, the 2 wheel drive version will have the lower shock mounts.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  5. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    What changed in 1988?
    1987 Blazer, Rancho 4"
