14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Jan 25, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    Hey guys, I just bought this kick butt 14 bolt from a junkyard. The tag on the outside was missing. However the code on the axle tube was "RFHG0961". Also when I popped the diff cover it had a serial # on the ring gear "1 GM 3992484 11 41 3 77". Also it seemed that the ratio was 4.11 when I counted the turns. My questions are, what ratio does this serial # denote, does the 3 77 denote 3.77's? Also how do I tell if it is a gov-lock model? Also, as far as mounting this beast, I know I need the trick u-joint, but I need to know where to get it and what part #. Also the 14 bolt was out of a 78 3/4 ton, so I think the spring perches are cool, but what about the shock mounts? Anyway I know I have alot of questions, but any help you all could give me would be much appreciated. By the way my Blazer is a 76 K5. Thanks.
    If in doubt, gun it.
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    The ratio is 3.73. In the serial number, the 11 41 is the tooth count. That is 41 ring gear, 11 pinion. 41/11 = 3.73. Hence, the ratio.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    The ratio is 3.73. In the serial number, the 11 41 is the tooth count. That is 41 ring gear, 11 pinion. 41/11 = 3.73. Hence, the ratio. The 77 indicates it was made in 1977. I don't know about the 3. Maybe, since it came out of a 78 model, the 3 designates 3rd quarter. Just guessing there, though.
    Brian
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    The 3 is the month it was made. March of '77 is when the rear was built.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. 76K5
    Jun 23, 2001
    99
    North Carolina
    how do I tell if it is a gov lock? And what do I need to do to the shock mounts. Thanks
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    peel out and see how many stripes are left :)
  7. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i guess just pull the cover and look at the diff. if it's full of complicated junk it's gov-lock but i don't know, i've never seen an open carrier.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
