14 bolt
Discussion in 'The Garage' started by smp92xj, Mar 10, 2003.
  1. smp92xj
    smp92xj Registered Member
    Sep 23, 2001
    14
    I just purchased a '89 k5, and am looking to do 1 ton conversions. found a 14 bolt for 200 less brakes. Has open carrior so I can put in a detroit. Swapping to discs also. Any suggestions on disc conversions, and anything else to look for.
    thanks
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Is it FullFloater?
    You can buy disc brake conversion bracket at A-tron... www.a-tron.net
    And if you use GM 3/4 ton rotors or calipers you wont have an emergency brake, if you want the ebrake youll need ElDorado Calipers.
    You can get the whole set at and alot of advice and isntruction at ... http://www.off-road.com/chevy/reviews/tsm/
  3. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I am in the midle of a disk brake convertion right now I will have about 250 into it when it is all said and done
    110 for new roters 85 for the brackets 50 for new brake pads and i already have the calipers
    a little tip don't use the cady calipers they are not worth tha hasel of tracking them down and they are pricy if you want a parking break just use a line lock like i am going to use or a pinion brake /forums/images/graemlins/thumb.gif
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Do a search, both of these Q's have been covered several times.
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    just a heads up on parts...if you order on line from kragen they knock about 20% off the price...
  6. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    its cheaper to go with the disc conversion then it is just to do a brake job, I wish I did, plan on doing the yoke on the driveshaft too
