14 boltcarrier FF removal, dang..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Aug 28, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok how do you get 14 bolt FF carrier to come outof the cas,eive rmeoved everything including pinion and related, all except the ring gear bolts, and it onlyis out of the case by about 3/8" if even that much,justwontcomeout.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The adjusting rings are backed out right?? If so give it a little pry and it should pop out. Careful it's heavy /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  3. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Once you've unscrewed the adjusters a 2 or 3 turns each it should come right out. Could it be that you don't have the axle shafts pulled far enough out? /forums/images/graemlins/confused.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep yep the adjuster, my bad,,. i realized this about 15minutes aftermaking this post, unscrewed them and the carrier fellout like it was nothing... ! the side load adjusters design is pretty neat, they should use that on the 1/2ton axles alsoi think
    im too used ot 10 and 12 bolts
    thanks!
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You did scribe the adjusters before turning them out right? /forums/images/graemlins/thinking.gif
    Rene
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    scrapping axle,already loaded in junk van, goingotpeoria shredder yard, i onlykept the 3.73 ring and carrier to sell or trade
    thanks
