14 boltff need some opinions
Discussion in 'The Garage' started by k5freak44, Feb 10, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    im thinking about putting some money toward a new rear axle and had a few questions.
    im looking at a 14bff 3.73 that is welded. he says he wants 175 for it but i think i can get him a little lower because he said he also has one in a truck right now that is open for 150 but he is unsure of the gears this one is in a 2wd vehicle.
    my first question is... what gear ratio do i have? I am 99.999999% sure they are the oroginal gears.
    2# - what is a good going price for a welded 14 bolt.
    3# should i go with the one that is welded and get a locker for it, or will it be ok running a full time locked axle in the rear as a daily driver.
    4# should i go with the one out of the 2wd truck that is open? will a 2wd rear axle swap the same way a 4wd axle will?
    thanks again guyss..
    JOhn
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Like I was saying last night the welded one is going to eat up your tires pretty fast on the street and it will be a little jerky going around corners. The 2wd and 4wd 14b's are the same except for the shock mounts, you will still have to move the spring perches so keep that in mind, I would get the 2wd one that is open.
  3. 502
    502 1/2 ton status
    Sep 9, 2004
    179
    California usually
    There are two reasons that come to mind why I would not recommend a welded up differential for a daily driver. The first, and of lesser importance, is tire wear. Increased wear is caused by what is commonly called "chuffing" or skidding that occurs as you preceed through a corner. This is caused by the difference in turn radius that the inside and outside rear wheels take through a corner. For example, if the inside wheel needs to make three complete revolutions to complete a turn, the outside wheel may require five revolutions to make the same turn. When a differential is welded up, the wheels are unable to rotate a different speeds and they fight against one another, each trying to turn at different speeds through the corner. Increased wear.:(
    More importantly, a daily driver is frequently driven at fast speeds and on wet or slippery pavement during winter months. Although chuffing may not be of great concern during dry conditions, the chuffing (binding) through a turn while on slippery pavement can get real exciting, real fast. When the ass-end of your truck breaks loose there is little you can do to control it in a turn. Major "pucker-factor". This is when you can really appreciate the handling characteristics of a limited-slip or part-time locker over a welded diff.:)
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    any time i want to go in the winter with more than 1-2" snow on ground its lock the hubs in and put tcase in 4 . the rear is always wanting to come to the front.
    dd=open if mostly dd
    trail or mud or crawling= locked
  5. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    thanks i think im guina go for the one thats 150 and ill try to get him down on the price a little too. :D
  6. sweetk30
    Nov 1, 2004
    25,546
    542
    dont forget open is needed for locker install for later use. good call for dd use.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    It should not be too hard to find something in the $100 range for a 14FF either.
  8. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    in plano texas it is. :crazy: ill try to get it for like 100
    ive got some haggleing skills. i got a deal on some hydrokodine that i never bought but i hagled the price down from 20 for 2 pills ro 20 for 1 pill :grin: .
    playing around with people is fun.
    and no i dont do drugs
  9. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    if its a 2wd you dont have to move the spring perches unless it from a 1 ton
