14 Bolts at the Bone Yard?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Jan 12, 2001.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I was at my local Pick N Pull the other day when I saw two trucks, an '80 and '73 both with 14b rears. Both of them had holes on the diff cover near the center. Is that the drain plug hole or did someone put them there. It was odd because both had them. They looked like bullet holes. Is this common or what??
    Rod
    BLAZER FOOD!!
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>My 14 bolt doesnt have that. That was probably done by the yard so they can remove the cover and count the gears. I have seen a few yards that do this.</font color=blue>
  3. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I have seen bone yards poke holes in drain pans to drain them i guess it is easier to do it that way maybe they are doing this to diffs to
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  4. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Would the rears still be good if I replace the diff cover and change the fluid? What problems might be cause by the hole, rusty gears maybe?
    BLAZER FOOD!!
  5. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Are they holes or perfect dents? My Blazer and Sub. have dents and on the inside are magnets.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    If they are holes, then as long as they didn't get filled up with rain water they should still be OK. I would pull the covers off and have a good look before buying though. If the yard put the holes in the covers surely they wouldn't mind you pulling the cover for a better look. Check for broken teeth, any sort of shrapnel or rust on the gears. Rotate the assembly and make sure it all works smoothly. If it checks OK lowball them anyways and re-fill it and just add a new cover.
    Rene
