14 Bolts FF Detroit locker install
Discussion in 'The Garage' started by 78blazaer, Feb 11, 2005.
  1. 78blazaer
    78blazaer Registered Member
    Aug 15, 2002
    36
    I am thinking of installing a detriot locker on my rear diff GM 10.5 14 bolts FF. Currently It has 4:10 gear ratio. Two questions:
    1. Can I use the same detriot locker when I upgrade to lower gear ratio (i.e., 4:56 or 4:88).
    2. How much should I torque the two bearing caps.
    I have been reading this article http://www.off-road.com/chevy/tech/detroit/ and It looks simple enough, I think I can do it.
    The only thing missing on the article is how much to torque the two bearing caps.
    Thanks in advance.
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am pretty sure you can use the same detroit since it doesn't replace the carrier just the spider gears. As of torque spec's.....I don't know but if you have a haynes manual it might be in there?
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    i believe the caps are 150ft/lbs, check the 14b bible over on pirate
  4. 78blazaer
    Aug 15, 2002
    36
    Thanks guys.. 135lbs of torque for the bearing caps according to 4x4pirate website.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I'll second the 135lbs spec. I just finished setting up my 5.13's- 135lbs according to the precision gear install book thingy.:)
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's much easier to find thicker 4.56 or 4.88 gears that will work on your existing carrier than it is to find the thin ones that fit the more-rare 4.56 carrier. The Detroit will fit into either carrier, but you'll most likely end up keeping the carrier that you have anyway. :cool1:
