14 Bsf ?
Discussion in 'The Garage' started by Chrisblazzer89, Nov 17, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Will a 14 bolt semi floater bolt right in to a blazer with a gm 10 bolt?
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    as far as i know it will,(if you come accross more than one with 373s or 410s let me know:D ) but what does that tell ya:crazy: :D
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    yes! but, you'll need new ubolts, ubolt plates and a conversion u joint.
  4. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    It needs to be a 14bsf out of a 80-87 truck. The 2WD and 4WD are different widths as well, but either should work (2wd will be the same as your current 10b, while a 4WD will be approx. same width as your front). Also, I doubt you will find a 6 lug axle in those years if that is what you're looking for. So far I haven't been able to confirm if 6-lug 14bsf were ever made for the OBS trucks, and believe me I looked. NBS trucks came with them, but if you use one you have to move the spring perches and shock mounts (which is what I did).
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    All good info.
    The 14Bsf was first made in 81 and up. The 81-87 version was only available in 8 lug(there is no such thing as 6lug version in the obs), while the 88 and up version was available in both 8 and 6 lug depending on the GVRW, but the 88 and up version had different spring perches, and shock mounts.
    Also I believe that you need to look at 3/4 trucks, 3/4 suburbans, 3/4 vans, and 1ton vans. Of coarse with a van rear end you will have to move the spring perches.
    Also If you do find a 81-87 14bsf there are after market axel shafts available for it to convert it to 6 lug. This what I plan on doing.
