14 ff carrier won't come out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Dec 17, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    14 ff carrier won\'t come out
    WTF,
    I can't get the carrier out of the housing on my 14 ff. I removed the shafts and all the bolts that hold the carrier in. I can pry it out partially but it still will not come all the way out. Any ideas? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/usaflag.gif
  2. Charly
    Charly Registered Member
    Mar 29, 2002
    28
    Portland, Maine
    Re: 14 ff carrier won\'t come out
    You need to back off the adjusters. Move just the left one and keep track of how many turns you needed to move it.
  3. 76K5
    Jun 23, 2001
    99
    North Carolina
    I took everything off, including the adjusters I did keep track of the # of turns I needed to make, anyway the damn thing still will not com off. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Prybar. Perhaps two, so it won't spin around as you lay into it.
    Back at the wrecking yard, we used torsion bars with one end cut off at an angle /forums/images/graemlins/thumb.gif
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    How in the world could you get the adjusters all the way out with the carrier still in the case??? On each side of the carrier bearings you should see a round sleeve with a bunch of holes in it. Take a screwdriver that will fit in the holes and loose them (as mentioned, just loosen the left side and count the number of turns). This should releave all pressur on the carrier and it should just lift out.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You shouldn't need to use a prybar on a 14 bolt carrier. well, maybe a little bit, but you'll hardly need any pressure on it. I think you need to back the adjusters off a bit more. </font color>
  7. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    I've used a big pipe, stick it in the carrier pry it against the housing.
    just give it a hard hit against the housing, it should just pop loose.
    /forums/images/graemlins/pimp1.gif <font color="orange">
    dogman </font color>
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    The prying works for most conventional carriers but just isn't necessary for the C14 FF. If you're lucky it won't fall when you back the adjusters off...but to be safe I usually stick a piece of plywood under the housing so if it does fall it won't chip a tooth or something.
    Are the axles completely out or just unbolted? I've done that.../forums/images/graemlins/blush.gif
    Rene
  9. 76K5
    Jun 23, 2001
    99
    North Carolina
    I took the adjusters all the way out. What the hell is going on? Do I have to take anything off besides the two main caps, axle shafts, and the adjuster nuts? /forums/images/graemlins/confused.gif
  10. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Once the main caps are off and the axle shafts are completely out there are two bent steel clips holding the side adjusters. It's one small bolt on each side. Remove these...then with a small round punch rotate the adjusters and be prepared to catch the carrier as it falls out. Scribe mark the adjusters and the housing and keep track of how many rotations the adjusters go.
    Rene
  11. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    Ok, I backed the adjusters all the way out on my axle too, I got mine out with some pulling, but now how to set it up properly again? Is this where gear marking compound and dial indicators come in handy? Is there a method to this to make it easy on me?
    andy
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
  13. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    and now that i have screwed the pooch, how do I get it back to working condition? Should I bring both adjusters back in evenly as a starting point?
    andy
  14. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Your pinion depth will still be OK, but you'll need to reset the ring gear using the adjusters and some marking compound. West coast differential's website has a good page on good patterns.
    You could also pm Shaggy, he recently set up some 5.13's in his 14 bolt.
    Rene
  15. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Actually you probably won't even need to run a pattern on it, you just need to reset the backlash. You'll need a dial depth indicator and a way to mount it solidly to the case. Then follow the instructions for setting backlash on a screw type diff. </font color>
  16. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    There ya go...thanks Shaggy! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Rene
  17. Charly
    Mar 29, 2002
    28
    Portland, Maine
    Shaggy is right, I just did one at the shop yesterday.
    "Once the main caps are off and the axle shafts are completely out there are two bent steel clips holding the side adjusters. "- tRustyK5
    Also, the retaining clips for the adjusters are bolted to the main caps...so removing the main caps means the retaining clips are already out.
  18. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    Ok this sounds like a pretty good deal. But, since there are adjusters on each side doesn't that mean that the ring gear can be moved left and right? What does that affect?
    Andy
  19. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hmmm, OK, go read the instructions that I linked to, and THEN ask your questions. /forums/images/graemlins/rolleyes.gif </font color>
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those adjusting nuts are what sets the backlash for the 14FF. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
