14 FF perch width ???'s
Discussion in 'The Garage' started by Masher, Apr 8, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    14 FF perch width ???\'s
    I'm getting ready to throw the new axles in my '96 1/2 ton and I thought the perch width for the rear was 42 1/2" which is what my 3/4 ton 14FF measures. I got under the truck today and the rear measures about 46 1/2" The new trucks must have different widths?? /forums/images/graemlins/confused.gif I thought it was only 40.5" and 42.5". I should have no problem putting the perches at that width right??
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Re: 14 FF perch width ???\'s
    Weld in perches in cause it obviously doesnt fit according to your measurements /forums/images/graemlins/thumb.gif
  3. Masher
    Mar 7, 2002
    123
    SW Michigan
    Thanks, yeah I plan on welding them in place anyhow so I can set the pinion angle. I just wanted to be sure they would be OK that far out, it puts them close to the 4-hole square mounting flange for the brakes.
  4. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Just make sure you can remove the bolts in the future or hope that you never have to change out the backing plates. When are you putting in you D60? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  5. Masher
    Mar 7, 2002
    123
    SW Michigan
    Thanks for the reply. I should have a couple inches to play with. I'm putting disc's back there anyhow so hopefully I won't have any issues. As far as the 60 I plan on having the truck done by June, so Hopefully I can start hanging the new axels in a few weeks. I've got a buddy coming over next weekend to help set the 5.13's and the Detroit in the 60. Can't wait to go wheeling!!
