14 ff pinion seal bearing preload Q
Discussion in 'The Garage' started by 86Cucvbeater, Dec 10, 2005.
  1. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    Hey I was reading old posts and saw one that said you can mess up the bearing preload when changing out the pinion seal if you dont use a new crush sleeve and nut. I changed my seal about a year ago and didn't know this. Is there some way to tell if my rear is screwed up or going to be? I used the same old crush sleeve and pinion nut.. just used a breaker bar and locktight for assembly. :doah:
  2. 86Cucvbeater
    May 24, 2005
    428
    north carolina
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Pull the pinion support, put it in a vice, use an inch/lbs torque wrench and check the running torque of the pinion. For new bearings it is between 25-35 in/lbs for used bearings I want to say it is 5-15 in/lbs. If it has been a year and you have no problems you are prolly good. If you only used a breaker bar unless you really put some ass into it you prolly did not change the preload. I just set up my 14FF and I had a 3/4 drive ratchet with a 3 foot cheater bar and it still kicked my ass.:D I went too far and I got the pleasure of doing it twice.
    Ira
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    My leaky rearend
    Would this be a pinion seal? I think I posted up in the past, but never got a definite answer. What other seals would cause this? I was under my truck working on it yesterday and noticed that it had gotten alot worse than when I took this picture.
    Where can I buy the seal(s)? How in the world to I learn to properly change it/them? what tools are necessary?
    I'm really concerned my 14ff is gonna be toast if I don't firgure this thing out.
    Thanks,
    James:bow:
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Yeah thats the pinion seal. It hides behind the steel cover.
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    so how hard is it to change? what tools/ skills are involved?
    thanks,
    James
