14 sf 6 lug drums & parts on a 12 bolt ?
Discussion in 'The Garage' started by big d, Apr 4, 2005.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    can it be done ?, gettin the idea from another post, im wantin better brakin' for less $$$$$$$, lol. all comments and info will be greatly appreciated. :cool1: :grin:
  2. dyeager535
    26,975
    Well wheel cylinders will interchange it looks like. Wheel cylinder changes on other vehicles have netted better braking without changing pad size.
    Most of the brake stuff appears identical on my 6 lug 14SF and my 10 bolt. The drum appears to be the same size or very close, I need to actually measure the brake pads, apparently two different sizes and not a whole lot of difference in the width. I have a feeling mine are the smaller ones since the drums are visually near identical in diameter.
    Perhaps earlier 14SF's are different, but my supposedly later (1997 I was told) 14SF has a drum with a hub section that is 1/2" to an inch taller than the actual braking surface. So the wheel mounting surface is that much further "out" on the drum. Likely that would kill the swap, as the 14SF drum would hit the backing plate before the drum "bottomed out" on the axleshaft flange.
    The backing plates won't be a bolt on affair, (different pattern) and they are different than the 10 bolt at least in how the drum "seals" against them.
    12 bolt stuff for drums should be identical to the 10 bolts.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    All the 14SF drums I have seen are much deeper than any 10/12-bolt stuff. There's about 4" of axle tube that sticks out past the backing plate.
    The other tough part is the center hole on the newer trucks is smaller. That means the newer drums won't fit unless you machine the drum or axle.
  4. big d
    Oct 24, 2001
    1,236
    illinois
    ttt
