14 yoke replacement
Discussion in 'The Garage' started by johnathan, Feb 3, 2007.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Is it possible to change the yoke wiyhout having to crush a new sleeve.Could'nt you just set it back to the same preload,maybe a slight bit tighter?If a new sleeve is a must where could I find one besides the dealer?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive switched yokes w/o changing the crush sleeve, and torqued it back to the same specs and never had any problems. weither or not ur suposed to...im not sure, it was necessary to let a friend borrow it since he destroyed his yoke on the trail and needed it to get home.
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Sleeves are $10 at the dealer, GM # 03977355.
    Other places, see this thread:
    http://coloradok5.com/forums/showthread.php?t=196188
    -- A
  4. goldwing2000
    goldwing2000 Guest
    The repair procedure in the factory service manual says you can re-use the crush sleeve, so I don't think it'll be an issue.
    Just make sure you measure the pre-load torque before you tear it down so you have a reference for re-installation.
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Thanks I feel a lot better !
