1410 Part#'s
Discussion in 'The Garage' started by keith, May 5, 2005.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    does anyone have the 14 bolt yoke part #? Is it a Spicer # ? same with slip yoke. Any numbers. Thanks Keith Found What i needed
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am going by memeory on the number so check it out first but this should get you what you need Spicer # 3-4-8001-1X for the 14FF 1410 pinion yoke.
    To many spline differences to know what slip yoke you need????
    HTH's Tom
  3. keith
    1,158
    La Fayette, GA
    I want to do the upgrade but was thinking it was a spicer 1410 yoke that came with u bolts. Is it a strap style that you swap to the u bolts?
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yeah , that part number should be for the strap style yoke. I never found a Spicer number that had the u-bolt style.
    Tom
  5. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    U-Bolt style yokes are not availible from spicer, they're aftermarket only. The stock yokes must be modified on a CNC mill to work with U bolts. We do carry the yokes with U bolts, or I can give you the part number for strap style - but I would never run straps.
    -Kyle
    NWF.
  6. keith
    1,158
    La Fayette, GA
    Okay got the yoke and a new slip and spline for the driveshaft. Had new joints put in and blanced $478 later :crazy: Damn this stuff is expensive
  7. keith
    1,158
    La Fayette, GA
    Added picture
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    So I guess this means it runs again? Did you get the front taken care of too?
  9. keith
    1,158
    La Fayette, GA
    Going to swap from the flange to yoke in front. I now have plenty of room with the doubler . Ordered the yoke from work 1350 and then need to order the shaft after I get the measurements.
