1410 to 1310 conversion U-Joint?
Discussion in 'The Garage' started by BorregoK5, Feb 3, 2003.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Now that the front and back of my np203 have the same output flange, I'm looking at making a spare driveshaft out of my old front shaft which I can adjust the length on for front or back use. Does anyone know if there is a 1410 to 1310 conversion U-Joint to make everything as simple as possible? This way I could bring one shaft with 2 yolks. If not, I'll head down another route.
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I SERIOUSLY doubt that they make one. I would be scared to run it if they did. Your talking about something to get off the trail, as in emergency fix, correct?
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yep, emergency only. I've got the extra shaft which is 1310 at the yolk, and an additional yolk sitting here. I'm just looking to make use of it through the U-Joint before I up and put a lot of work into it.
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Have you tried getting 2 standard 1310 ujoints from AZ and then buying a 1410 ujoint and putting the caps from the 1410 onto the 1310s? Making your own? You would have to measure the bearing shaft and make sure they're compatible, might even have to use an already trick 1320/1350 ujoint to begin with for the length from one cap to the next to get that part right! Just a thought!
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've got a 1/2 ton to 1 ton NAPA conversion joint and a few others standard u-joints for comparison but the bearing shafts are all different sizes as the size increases. I may just have to mill this yolk out for a standard 1410 joint... so much for the easy way.
