1410 u-joints
Discussion in 'The Garage' started by BAD4WD, Oct 18, 2002.
  1. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    How much stronger are they then the 1350? I know there caps are the same size but the 1410 cross width is bigger. Doesn't seem to be that big of a differance. /forums/images/graemlins/truck.gif.....1-ton or go home...
  2. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    i think they have a better opperating angle than the 1350 but i'm probbably half wrong /forums/images/graemlins/rotfl.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I would say the 1350 would be stronger because when you move the caps outboard more, you put more stress on the cross shaft.
    But I do agree the 1410 would be better for those with lifts in order to get a better operating angle for the driveshafts.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so a 1310 or a 1330 would be the strongest of them all?
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, not stronger than the 1350 because the caps are larger in diameter than the 1310 or 1330. /forums/images/graemlins/wink.gif
    If you were comparing the 1310 and 1330 to each other, then yes, the 1310 would be the stronger one.
    But when you go to larger diameter caps, there is more material and that adds extra strength there. Just when you take the caps out further, like the 1410, the cross shaft gets weaker. /forums/images/graemlins/wink.gif
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 1410 is stronger by a fair ammount. All u-joints end up having the same forces (moments) acting on the cross (it is the driveshaft torque). When you make the cross larger and keep the caps the same size the caps end up having less force on them which puts less load on the needles and makes them last longer. It also puts less stress on the cross where the cross necks down to be able to fit the neddles (which is where the weak point is on most u-joints).
    Does that explain it clearly?
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think the main reason for going to 1410 is so you can get rid of the strap type of pinion yoke in favor of a u-bolt style. The u-bolts are alot stronger then the straps. Other then that I don't think you will brake a 1350 (and that is what I stuck with for my 1-ton CV d-shaft)
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    The way I've read and heard it is the wider the cross, the better it will operate for steeper angles from lifts.
    But when the cross shafts get further away from the center, it puts more stress on them. This is why the 1350 would be stronger.
  9. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I disagree. It really seems simple to me-- more material equals stronger u-joint. I agree with the 1410 having more clearance at sharper driveshaft angles. I have one at the diff. end of my front driveshaft and it has more clearance than a 1350 at the diff. Also, the factory Spicer yokes (1350 and 1410) both use the strap style attachment from the factory. Jesse at High Angle Driveline drills out the yoke to accept the u-bolt style attachment. So, the main reason for going to 1410 is to have more clearance at steep drivline angles, but I still think the 1410 is stronger than a 1350.
    Will
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what you been smokin Wes?
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, I give up. /forums/images/graemlins/tongue.gif Everybody is entitled to their own opinions, so, I guess the only way to find out for sure which is stronger is to wait and hear stories from those who have busted the 1350 or 1410 joints. /forums/images/graemlins/tongue.gif
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I busted a 1350 at the rear of my rear end driveline. The cross did not break, that caps and drive line ear exploded. One of the straps held one cap in the yoke and the other strap was waisted, let me know if you can see this pic...
    So now I have a 1410 coming in the mail I'll try to break that one too and get back to you all /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    never broke a 1350 or 1410 but the 1310 blowed up real good
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  15. Burt4x4
    6,854
    aaaahhh gotcha....basterds /forums/images/graemlins/eek.gif
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you can link to the page in your 'community' section but cannot hyperlink the image itself
  17. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    forbiden
