1410 Yoke for a slip 208...?
Discussion in 'The Garage' started by marv_springer, Sep 18, 2006.
  1. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I've seen rear slip yokes [mates w/ the 208 rear output] in the 1310 and 1350 variety, but did they ever make them in a 1410...? :dunno:
    Marv
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Hack and tap SYE that thing for a standard yoke and shaft combo.
  3. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Check the classified section. Someone is selling one that was custom made. IIRC $70 shipped.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The bad guys list a 1410 non cv yoke for 32 spine th400's
    [​IMG][​IMG] Transmission Slip Yokes
    1410 new process yoke. Again, this yoke can be used in the same applications as a turbo 400 32 spline yoke above. However, the u-joint is a heavy duty ton and a half
    1410 32 spline yoke -- $175.00
  5. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Matt,
    Please post up to 85mudblazin on this post.... My membership has lapsed - and I've paid - but I can't yet PM or post in the FS section...
    Marv
  6. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Done. You have to run normal joints with that set up BTW. But they will offer more angle.
    You can also cut the slip down a bit and hack off the same amount from the tail shaft. Drill and tap the tail shaft, make a new shorter tail housing for the gear/seal system and run a normal drive shaft.
    Keeping the slip in line with the D-shaft takes away the bending moment about the tail shaft. This in turn keeps the t-case system from bucking as much since the slip yokes are notorious for thier high friction while under torque. Just another complicated way to not spend money on a bling atlas or a stak or a doubler (even though some of us have had all 3 in our garage at the same time)
  7. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Thanks Matt.....! :waytogo:
    Marv
  8. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    All very true.....
    I'd really like to find a solution that does not require modifying the case. It keeps the "interchangeable factor" high if I don't start modifying cases. Good example is the case repairs I just did.... I swapped position of the front/back cases and it was easy. I don't want to have a bunch of special mods to either case.
    And remember.... I wanna build another one of these buggies.... [Marvota..??? ...or Marvtsubishi..???] and I need to know what works and what doesn't.
    One thing for sure... I underestimated how difficult it would be to hold on to a couple of dumb ol' 208's.. :doah:
    Marv
  9. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I still vote for drilling and tapping even with the normal un-modified set up. The drive shaft won't get any shorter and you can run the singel joints at off angles. I have for years. My rear diff is almost aligned and my t-case side is near 12-13° and it only vibes a bit when letting off the gas above 45MPH (not an issue in the beetle)
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My 1410 yoke worked perfect for my needs, it never let me down. I was having some big binding issues even with the caddy CV I used to have, this setup offers more angle then that ever did. After pulling off the yoke today there were some marks where I could tell it was binding, but then again my rear shaft wasnt the longest and my rear drooped like 15". Nothing but a high dollar CV could fix that.
  11. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yep... sounds like it's worth a try.
    Paypal..?
    Marv
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    So a slip shaft from a th400 application will fit in a 208?
    Ira
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I'm guessing so.....
    I know they are both 32 spline.
    Marv
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea deadeyetoph@yahoo.com.
    -Chris
  15. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    :haha: :haha: :haha: :haha:
