1410 yokes (Update - need yokes soon!)
Discussion in 'Parts & Trucks Wanted' started by BadDog, Mar 11, 2003.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Dana 60 slugs for 30 spline (or 35 spline)
    1410 yokes for 32 spline 205 outputs
    1410 yoke for D60/D70 pinion
    1410 yoke for C14FF
    Shafts with 1410 yokes.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Re: D60 slugs, 1410 yokes, 32 spline 205 output
    Still looking
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    TTT
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Sounds like you're planning on beefing up your drivetrain. I likey, I likey!!!
    Are your plans as obvious as the needs you posted?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Pretty much. /forums/images/graemlins/deal.gif
    Here is the long term plan which will progress as fast as I can find the parts for a good price (and save the money up).
    <ul type="square">
    [*]1410 joints all around with shafts from Jess (unless I get stupid lucky and find some, never gonna happen). I think I can have front and back shafts identical that way. Only 2 spare joints, D60 knuckle and a 1410. One spare shaft for either position. This may require moving the rear axle a bit, but it's close. No bid deal, I'll probably be linked by fall anyway...
    [*] doubler
    [*] 32 spline yokes front and rear on the 205
    [*] 35 spline stubs on the D60 with slugs.
    [*] Looking for a K30 for my son. May get a dually and swap axles with him so I can go low geared (D70 rear) and run Hummer bead locks.
    [*] As already stated, link the rear, maybe even the front...
    [/list]
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Still looking...
  7. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    What are slugs???
    -fLeXy K20
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Drive flanges; solid steel peices that replace the lockout hubs. </font>
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Anyone?
  10. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have some 30 spline dana 60 slugs with the spacers but with no caps make me a offer.
    Colin
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Finding the caps would likely prove a problem. Funny, your not the first person who had slugs with no caps. What are people doing with the caps? /forums/images/graemlins/crazy.gif
    I've got a line (supposedly) on a complete set so let me see how that plays out. I should know something early next week... Thanks...
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Up again...
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, I've got the other stuff. Wound up with Warn slugs for 35 spline stubs, and I built a 205 with Ford parts so I got the output shaft now. I also got a 1410 for a D60 (thanks Shawn/ript! /forums/images/graemlins/thumb.gif)
    But I still need driveshafts wtih 1410 weld on yokes (just the yokes actually, cut off the shaft makes shipping easier). That's a total of *4* of the weld on yokes...
    I also need 2 1410 yokes for 32 spline 205 outputs. These can be found on late 80's, early 90's Dodge 3/4 ton and up with a Cummins (maybe others?) and 205. Also, chassis cab 4x4 GMs, and maybe Fords? Anyway, I need *2* of these.
    And lastly, C14FF yoke. This will never be found (even less likely than those above /forums/images/graemlins/frown.gif ) but apparently came on some heavy cargo vans and chasis cab with high GVWR.
    If I don't find something in the next few days, I'll just have to order new from Jess'. But the pocket book is a hurtin' after doubler and 35 spline D60 upgrade... /forums/images/graemlins/crazy.gif
  14. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    i got a bunch of drive shafts so shoot me a pm with what ya think is a fair price for me to cut em up for ya and might even have a yoke or 2 4 ya
    randy /forums/images/graemlins/usaflag.gif
