1480WJ lube mod thoughts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by michaelm, Sep 28, 2001.
  1. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i dont have the new joint in my hand yet but am interested in opinions on drilling the end caps for a small needle type grease fitting from a cv joint. might have to grind a groove in the end of the cross to send the grease out to the rollers, have to see when i pick up the joint.
  2. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    Why did you post it three times?
    Never put a stupid move passed a stupid person.
  3. michaelm
    Feb 2, 2001
    872
    i certainly had no intentions of that occurring.
    i am unable to delete the spawn.
    my connection was hanging.
    i apologize and have sent an email to the admin hopefuly he/she will correct it.
  4. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    Re: 1480WJ lube mod thoughts
    The 5-332x Spicers have a casted boss w/flat spot on the cross that is neither tapped or drilled out for a grease fitting. I suppose you could drill it out and use a self-tapping grease fitting, perhaps one of those low profile button style grease fittings.
    At $50 per u-joint you would think they would be serviceable.
    Joe
    79 K10
    68 K20
  5. michaelm
    Feb 2, 2001
    872
    so they do!!!
    now i am thinking the WJ is just different caps and if i order a 1480 and use the WJ caps i will have what i want?
    5-188x might work...may knock the lube fitting off if it is a standard style. hmmm
