14B Can I tell if rear end has posi or gov lock without opening cover
Discussion in 'The Garage' started by stano, Mar 17, 2006.
  1. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    Can i tell if the 14B rear end assembly has posi or gov lock without opening the rear end inspection cover. Can you tell be rolling it over? or codes??
    thank you
    87 K5
    stano
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If its an open diff the tires will rotate the opposite direction if you lift the whole axle off the ground and spin one tire. I posi will spin both the same direction. As far as what type of limited slip or locker, you'll have to pull the cover.
    The 14B gov-bomb is the strongest of the bunch, but you never know...
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the gov lock might have exploded or be worn, so that trick wont always work. i know it wears your hand out, but pop the cover anywho.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, even with a gov lock the wheels will spin independently, since it acts like an open diff until it senses wheel slip then locks up. Pull the cover. If it has a case like in the pic, then its open (dont mind the yellow circles). Also an open diff has a 4 "pins" in the caser (where the case bolts together) and a gov lock only has 3, also the gov loc is smooth and you can see the clutches. Or you can simply look in the glove box at the RPO codes, id theres a G80 then its a gov lock.
  5. stano
    Jan 24, 2005
    130
    Iowa
    No G80 on the glove door. So best way is to open and look. Thanks
    87 K5
    stano
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    14 bolt open:
    Note the four cross shaft design
    14 bolt gov lock:
    Note the three cross-shaft design.
    You can see the three countersunk screw holes that hold the two halves together. The open carrier does not use these screws.
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    There was a post here or on Pirate that showed what to do.
    Lift up both sides of the axle - spin one tire and watch the other.... if it's a gov lock it should spin the opposite direction at first. As you spin the 1 tire faster and faster the other one will slow down, stop and then begin to spin the same as the one you were spinning.
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    All of the Gov Locks axles that I've seen have a rectangular, black sticker on the cover (probably 2.5"x3.5"). The sticker doesn't say anything it's just black, I believe it's simply a marker for the factory/dealer to know to use L/S additive in the gear oil.
    On older stuff the sticker may be gone but you can usually see the outline of where it used to be.
