14b disc brake bracket mount position
Discussion in 'The Garage' started by BigOrange90Jimmy, Aug 4, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I just received my 14b disc brackets from Echobit and I was wondering which direction they are supposed to face. Do they clock backwards like the front calipers do, or should they clock towards the center of the truck? It's probably a stupid question, but I am going to be VERY detailed in how this truck is going together, and I want it to be right. By the way, the brackets are AWESOME!!! /forums/images/graemlins/thumb.gif
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I think most are clocked backwards but it mostly depends on your bleeder screw position. Whichever way makes that the high point so air can escape.
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Yep try to get the bleeder in the up position. Most bracket's are rotated to the rear, while looking at hub. say about the 2 o'clock position.
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    that makes sense...thanks guys!
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Not to disagree, cause I'm actually agreeing.... But the bracket is just as they say, dependent on the calipers... You could also run the bracket at 10 Oclock and then switch the calipers, R for L, and L for R. I say wait till you put your hands on the calipers you're going to use and mount them up without the hub on, that will give you the best location for the bleader screw!
    PS. different calipers mean differnt locations. I just slapped my Cadi brackets on thinking that the bleeder was in the same location, but it ended up being different from the 3/4 ton calipers..... Just to let you know! /forums/images/graemlins/thumb.gif
