14B disk swap/I'm P!ssed
Discussion in 'The Garage' started by broc944, May 13, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I installed my 14b about 750 miles ago totally rebuilt along with Disc brakes. Last night on the way back from a ride I heard what sounded like a rock rubbing on the disc. What I heard was the wear indicator of the pads, the pads are totally gone, grooves being cut on the inboard side of both discs, pads on both sides of both discs are gone. Everything I used was new, nothing rebuilt. WTF over?
  2. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    that blos
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    prolly just cheap pads... ive had that happen to me before...
  4. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,803
    388
    Clayton Del
    Wonder if the pads came unglued ??
  5. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    But in that amount of miles? I can not believe even the cheapest of cheap pads could not survive for 750 miles.
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Think about it for a sec...is quality control on the cheap pads company gonna look as hard...? so questionable pads may get through. LAtough most brand x pads last a good while some of there questionable ones may make it through...you may have just gotten a few bad pads.
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    How's your brake equalization?
    Did you change your P-valve?
  8. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    It seems fine to me, I was sort of amazed at that. I used to race, so I am very familiar with proper proportioning. I do admit it is difficult to truly judge how a a big truck is doing compared to a 944, but I feel the brakes are dialed in correctly, if anything I was going to give the rear a bit more just due to my driving style. But I think maybe after I replace the brakes I will do the opposite to see how it feels, maybe I need to relearn how to drive, was having trouble drifting in the corners with the Burb:D .
  9. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    This I do not know, what exactly would I be looking for?
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    no. our trucks are not equipped with one.
  11. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    And actually I would say a week after the the axle swap, I had jacked the entire rear of the truck up, to check for anything unusual/verify the ARB was actually working, etc. There was absolutely no brake binding/dragging what so ever.
  12. 79k20350
    Nov 22, 2004
    7,757
    Ct
    I thought it was established that by looking through parts blowups that none of our trucks ever came equipped with em....hmm...
  13. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    I have read a lot of the old posts. Even if there is a residual pressure valve, I can not believe it would wear my pads down this fast and start cutting grooves into the rotors. Sand/mud getting caught up in there? My work fan suffers from this also, but it is a design flaw that the dealer is aware of, the rotors stick way out in the open. Others on here have to have done the disc swap and drive out in the mud like myself. Am I the only one that has had this problem? Rally need some ideas on what the cause of this is.
  14. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Its got to be the pads fault. I can't see how anything else could cause that to happen.
  15. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Thats pretty much my conclusion on this matter also, I will replace what is needed and inspect what is happening every time I go out. Sloppy gravel roads and trails is all I drive on. I bought the calipers fully loaded, so I am sure they probably had el cheapo pads on them. I will get something better tomorrow and see what happens.
  16. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    did you grease the pins enough? if you go through deep water/mud that will gum them up too. once they are sticky the caliper can't move and the inside pad gets wasted in a hurry. if the inside pads are shot and not the outside pad this is the first thing i would think of.
  17. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Both inner and outer are gone, both sides, very even wear.
  18. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Same deal here, although, not as severe as what you have there. Mine have worn down pretty quickly, kinda suprised me too, i was able to get several months out of them, but they still worn down MUCH quicker than the fronts.
    I am leaning towards the idea of the proportioning valve being the problem, probably need an adjustable one, or one designed for disk brakes.
    What i mean is that the P-valve is letting more pressure go to the rears than the front, not enough to really make it noticeable, or lock up real easy, but more than normally should,,,,,,i am glad i bought lifetime warranty pads :D
    When you get the new pads, bend that wear indicator in slightly further, so you have alittle more advanced warning.
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    In your case, if all you have is teh stock prop valve, you DO need a new one. ALl you need is one inline on the rear brake line and dialing power down from them. The stock prop valve does nothing at all for the rear brakes, it is a 100% front brake thing.
  20. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Both very good ideas which I will do, I do have a stock prop valve in place, I like the idea of mounting a after market one inside of the cab so I can adjust it on the fly.
