14b drums +15" wheels
Discussion in 'The Garage' started by Jonny-K5, Nov 25, 2005.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    did a search but didnt find what i was looking for
    i've got a 1ton 14b out of a 78' 2wd camper special. it has massive rear drums. do 15" wheels fit over these? rims will have 4" backspacing. do you have to run discs on the rear to use a 15" wheel? i'll eventuall swap to discs, just wondering if this is possible.
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    friend has 15x10" 8 lugs wagons on his no problems.
  3. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    as i understand it, if get rims with the right backspacing it's not a problem.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Disc will NOT fit with 15"
    Drums are fine.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    the fronts you mean,,,right? if the front end is setup with 3/4 or 1 ton stuff, you will need to grind down some of the caliper until it doesn't rub the rim,,,the rear WILL fit either disc or drum no problems.
  6. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    if you put disks in the rear then you need to grind the calipers to fit 15" rims unless you find the kit made for 15" wheels. i have 15x10 with 4" of backspacing on my 14bff and they clear the drums fine.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    well i've never heard of a kit for "15" wheels",,,a disc brake kit is a disc brake kit when i bought mine,,,they fit no problems.
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, i may be wrong...that is just what i have heard.
  9. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    I put the Sky Manufacturing disk kit with 70ish (don't remember exactly what year) 3/4 ton front calipers. 15" rim with 4" of backspacing fit just fine.
    Eric
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    fits no problem
  11. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    sweet. but i have to grind the front calipers on a 3/4t 10 b? bummer. i was hoping that was only nessesary on the dana 60.
