14b F/F Hub bearing install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Jun 18, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Which way do the outer races go in on a 14b F/F hub bearings (I believe they go in w/ the tapered end out, requiring the bearing to put in at the same time)? Also, is the outer race supposed to seat against the internal snap ring?
    Like a big dummy I tore both hub assemblies apart after digging this rear end out of a junkyard, so I can't compare to the other side /forums/images/graemlins/mad.gif
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I don't remember what direction they face but the outer bearing goes in before the race goes in.
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    What about that snap ring?
    Does the outer race seat up against it?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Yes, the outer race seats against the snapring.
    You drop the bearing in, drive the race in with the tapered end facing out. Then you put the snap ring in and drive the race back against the snap ring. Then you drive the inner race in and stick in the bearing and the seal. Have fun /forums/images/graemlins/smile.gif
  5. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Cool...
    Thanks for the help!!!
