14B FF, Caddy Caliper Banjo Bolt
Discussion in 'The Garage' started by AZ_Overdrive, Nov 10, 2004.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Just wanted to nail down the appropriate banjo bolt for the 78 Caddy calipers on my 14B disk conversion.
    I have seen Raybestos part number H5370-2 in other posts(what was the original application for this part number?) /forums/images/graemlins/burb.gif but I wanted to verify that it is for the Caddy calipers (NOT chevy 3/4T fronts).
    Also plan on using the 79' Chevette front brake lines to connect calipers to the hard lines.
    Thanks for any assistance.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    For a Cadillac Eldorado with rear discs motormite # 313935 , regular Autozone store stock , 1.99 . Its cool , nearly all the parts stores has online lookups . Now any store can cross that number I'm sure /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    The H5370 banjo bolt p/n is correct (7/16") and it is used in both the cadillac and 3/4 ton GM trucks.
  4. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
    Thanks for the info! Here is what I found at AutoZone(online).
    Motormite 313935 - is the stock banjo bolt for the 78 Caddy.
    Motormite 313940 - was listed for my 89 burb and for an 80 3/4 pickup.
    I haven't checked on the H5370 but Checker can order some for me (2 day wait) but they cannot tell me the application.
    I just want to make sure when I do the swap this weekend that the Chevette rubber lines will mate up with the Caddy calipers correctly.
    If the stock banjo bolt from the caddy works on the Chevette lines then I am all set as the calipers have all the original hardware on them. I wasn't sure about the banjo bolt since the caddy calipers have a rigid block attaching the hard line to the caliper but I guess so do rubber lines on the ends.
    Anyway, thanks for the info.
