14b ff differential removal
Discussion in 'The Garage' started by stock93, Apr 22, 2004.
  1. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    Is there a website or something documenting the procedure for doing this? Its not in my shop manual and I cant seem to get the differential out. Its stuck in there pretty good.
    John
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you undid the bolts that hold the wire clooking clips in place right ? the clips that have the ends that go into those little holes you see on each side of the carrier at the side bearings ?
    good luck
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Also not trying to make you sound bad, or stupid, but you did take the shafts out right???
  4. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    Yes I took the little c looking clips out that are bolted on. I also took the shafts out. It can get it to come about 1/3 of the way out but not all the way.
    John
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    time 4 BFH and BFprybar /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    can't go wrong with that method....
  7. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    try rotating the pinion end up and using a big punch, pound it out fromthe inside out /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  8. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    Did that...didnt budge. I'm using a 16 lb bfh and a piece of 1 in round stock. Any other ideas.
    John
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Loosen the udjuster sleeves/collars more (don't know the proper name for them in a 14B). I have pulled mine out a couple of times and always had to lossen the collars about 2.5 turns in each side and then it would fall out in my hands (it is pretty heavy the first time you catch it).
  10. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    Ok. I completely feel like an idiot. I didnt realize there were threaded adjusters in the housing. Its out now. Thanks guys. Does anyone have a set of 14b ff adjusters just laying around in a junk axle? I kinda tore mine up.
    John
  11. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Try HERE.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  12. stock93
    Feb 18, 2004
    68
    Huntsville, AL
    I found that last night. Its what made me realize what I had done wrong.
    John
