14B FF Disc brake conversion Question
Discussion in 'The Garage' started by Mudbug1979, Jun 10, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Who all has done this and has a problem with it feeling like only the front brakes are working? Do I need a porpotioning valve or a new Master Cylinder to help them out. I just put them on and I'm not that impressed. What do I need to do? /forums/images/graemlins/1zhelp.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    bleed bleed and more bleed. It took forever and a day to bleed mine. Eventually gave up and they got better until finally I cracked the bleeders again and the last little bit of air came out and that was that. I think the reason it takes so long to bleed them is the master cylinder doesn't push the volume that the calipers should have. Drums require less volume due to the size of the wheel cylinder versus the caliper. Now when I stomp on mine on gravel the rears will lock up. Done this to 4 trucks now and haven't needed a proportioning valve or anything yet. My best friends truck we got it working in about an hour so I don't know why that one was so much faster. Most people have good luck gravity bleeding them overnight.
  3. Mudbug1979
    Aug 4, 2002
    439
    I believe that I figured it out. We use a pnuematic bleeder at our shop and I'm sure I got all of the air out. I put them on upside down. The bleeder is pointing down therefore the resevoir can't fill up. It's been a long long long day, geeeeesh. /forums/images/graemlins/dunno.gif
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Don't feel bad. Your not the first to have done that.
    /forums/images/graemlins/waytogo.gif
  5. Mudbug1979
    Aug 4, 2002
    439
    OK, I flipped them over this morning and bled the crap out them ( not literally) . Still doesn't feel like they are up to their full potential. I would think that I would be able to lock them up on gravel. It still feels like the front brakes are doing all the work. Do they just need to break in a little bit more or what do I need to do? /forums/images/graemlins/1zhelp.gif
  6. Mudbug1979
    Aug 4, 2002
    439
    Anything, Anyone? /forums/images/graemlins/dunno.gif
