14b FF out of a Van...
Discussion in 'The Garage' started by Swanson52, May 16, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Has anyone ever hooked up with one of these? I picked one up today and am wondering if the only thing I need to do is move the spring pads...TIA
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    some vans have them in the right place for a K5...
    J
  3. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I am using one. I had to move the spring pads and shock mounts. I needed new u-bolts and hold-down plates. You may also need a hybrid u-joint. I had a new driveshaft made (converted to a cv-style).
  4. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    If you run any lift at all you'll probably want to move (rotate) the pads to set a good pinion angle anyway. Most 14B pads are cast and are a bitch to get off. Lots of torching and air chisel will get it done. Good luck.
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I have one and love it. Most people dont even notice it till I point out the old, cast spring pads. I just left them on (for looks) and welded on new pads- at the pinion angle I wanted.
    G30 14BFF is the way to go.
