14b ff pinion shims
Discussion in 'The Garage' started by mechted, Jul 2, 2004.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    I went looking for a 14b ff at the junkyard today, but someone already pulled the pinions out of all of them. I found one on a 77 Chevy with the pinion laying next to it, but I need info on reinstalling the pinion. What do i do if i don't know the size of the shim? Or can I just bolt it back in?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Install it, run the pattern, and adjust from there. Without checking pattern and backlash it's a shot in the dark.
  3. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i think all the shims are in the pinion assembly /forums/images/graemlins/dunno.gif
    defenatly check the patteren and backlash after you put it in /forums/images/graemlins/waytogo.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The shims he is talking about are for setting pinion depth not pinion preload. These shims go between the axle housing and the removable pinion support housing. /forums/images/graemlins/thumb.gif
  5. mechted
    Oct 19, 2003
    767
    Granbury, TX
    ok, well got the 14 bolt today... grabbed everything that looked like it came from the axle (1 shim?), and im hoping it will all work out... just need a new diff cover and the u joint now /forums/images/graemlins/smile.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Check the pattern!!
  7. mechted
    Oct 19, 2003
    767
    Granbury, TX
    Check the pattern!!
    whoops... meant to say that i will do that, sometime in the next few days /forums/images/graemlins/grin.gif guess my fingers forgot about it when i was typing last post /forums/images/graemlins/crazy.gif
