14b ff problem
Discussion in 'The Garage' started by dieselponyexpress, Apr 3, 2005.
  1. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    I'm hearing some noise from my rear axle (14b ff detroit) driver's side. It's not the "detroit bang", but a squealing sound, like a bearing maybe.
    Also my tire is rubbing on the ground if driving left turns.
    Again, I don't mean the detroit locker behaviour - I'm driving the truck 7 years as DD and know how the locker feels.
    On right turns everything seems allright.
    Oil is filled up, but a little contaminated (gray).
    I pulled the left axle shaft and discovered nothing unusual but I missed the few splashes of oil coming out of the tube. Could there be some kind of plugging between the diff and the outer bearings?
    Should I change the wheel bearings as a first step?
  2. poorboy1
    poorboy1 Registered Member
    May 26, 2004
    56
    Newberg,OR
    does the hub make any noise when you spin it?
  3. dieselponyexpress
    Jan 26, 2004
    220
    Germany
    No noise with only the hub turning (axleshaft removed).
    But there seems to be some unusual sounds with the axle lifted and tc in neutral. It's a little difficult to determine because of the locker noise.
    I will pull the cover during the next days and inspect the diff bearings.
    I have a dial indicator for setting backlash, but no wrench for the adjusting nuts. Do I need this wrench?
    Any other special tools or parts required?
    Other items to be serviced while I'm that deep inside?
    Thanks in advance.
  4. dieselponyexpress
    Jan 26, 2004
    220
    Germany
  5. dieselponyexpress
    Jan 26, 2004
    220
    Germany
    wow!
    Nobody ever changed diff bearings on a 14b!! :crazy:
  6. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Sorry would help you if I knew, just look at tech sections of truck sites like this one and start taking things apart :dunno:
    I have to send my truck back to CA next week so I wont be able to drive with you this summer :frown1:
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Pull your drums off and do a visual inspection of the hub berings (check the inner race of the berings). Pull the cover off and take a look at the carrier berings - these will be a little more difficult to inspect without pulling everything apart, but if they are what's making that much noise, you should see some damage.
    Report back with your findings.
    Eric M.
