14b ff shafts
Discussion in 'Suspension | Axle' started by protechk5, Mar 15, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    got some 14 bolt ff shafts from a k30 single rear wheel truck. $45 plus ride from 22039 which will prolly be alot
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I might be interested, depending on shipping cost. Can you weigh them for me?
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    yeah ill do it first thing in the morning, im not at my house right now
  4. protechk5
    Sep 26, 2004
    2,015
    VA
    yeah both shafts are about 33 pounds together
  5. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    If you can close the deal and ship ASAP i will take the right side now.
    Im kinda in a wierd situation, i need a new axle bad(mines shattered in pieces) and i honestly cant find a 14b ff here in fl, the only one i did find if missing the right axle shaft.
    if i know i can get the axle shaft, i will buy it. Would you separate them? if not how much for both?
    I am going to search, but are there any differences between 14b FF splines between years? i think the one i was looking at was an 80s one 14b FF SRW c20
    ken
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Should be no difference in spline count on any of the 14FF's from '73-87. I think there was a slight change in the axle shaft length when they went to the slip on brake drums (studs not pressed in from the back thru the drum). But I don't think that change took place until the 90's.
