14b FF spring perches???
Discussion in 'The Garage' started by firefighter184, May 2, 2006.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Getting a 14bolt this weekend, 4,56 gears, it's out of an 80 3/4 ton (I think). Will I need to move the spring perches or will it bolt right in?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If its going under your 89, and its indeed a 3/4ton 14FF, then no, you don't need to move the perches.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    x2 bolt in, as long as its a 3/4 ton:D
  4. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    If it's a 1-ton, will they need to be moved? I have a welder, so I'm not too terribly concerned, but I'm hoping to bang this thing in quick.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, if its a 1ton, they will need to be moved
  6. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    Just talked to the guy, it's a 1-ton, with a gov-lock, out of an 80 single rear wheel truck.
  7. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    So now I need some tech advice on what I need to do (tool and technique-wise) to move these perches. How do I get 'em off? I assume welding them back on will be pretty straight forward, but how do I get 'em off?
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You will also need to cut the shock mounts off as well. They are opposite of 1/2 and 3/4 ton mounts and also mount crooked instead of straight. As for the spring perches, if they're full cast i doubt you'll be rewelding them back on unless you spend hours cutting them off nicely with a small cut off wheel of some sort. I would just make a nice new set of steel perches out of some 2.5" square tubing and then you can also build a certain amount of lift into the perches if you like.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Depends on if you want to reuse the originals or get another set to weld on/build another set to weld on. If your going to get/build a new set of perches, take them off any way you want. If your going to try to reuse them, use a cut-off wheel and cut them off at the axle tube as close as you can. Or if you have access to a plasma cutter, your golden :thumb:
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    If the are the stamped type, I wouldn't re-use them. My 14b in my 3/4 has what look like cast mounts, very beefy.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, when I swapped my 14FF under my burb, I made new ones out of solid 2.5" bar stock :eek1: nothing like having solid steel for spring perches :D
  12. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I like these clarkjw24 made.
  13. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    The stamped ones on my 1 ton axle were more than a 1/4" thick everywhere I cut them off and reused them they were really beefy. Cutting them off is a pain though. I think the best way to weld them back on is to put them on the axle and then jack the axle up to the leaf spring use a hammer to move them side to side get all the weight on the springs and use a hammer to set the pinion angle tack weld remove and finish weld
  14. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Both time I did the swap I cut them off and reused them. Both sets were stamped and I had no issues. I used a grinder with a cut off wheel and cut the welds pretty good and then smacked them with a BFH to get them off. If you are using a 1980 rear I think they will be cast mounts which you can do the same thing with. I used shock mounts from a junked 10 bolt the first time and fabbed my own the second time. I put the axle under and set the pinion angle and centered it up where Iit need to be and tacked the mounts in place. Put everything together and made sure it was right and took a test run. Once I was happy I welded the mounts up.
  15. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Here's the stamped ones I was refering to.
  16. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I ordered the spring perches and shock mounts from DIY4x. Cuttiing the old perches off is the hardest part.
    John
  17. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    Thanks for the info guys. I'm thinking I may be a little over my head here. Gonna have to find somebody who knows what the hell they're doing. Pretty sure the Colorado Crew should have somebody qualified. Where's Harley?:D
  18. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I just checked out DIY's perches, look good and stout to me. One question, I do have a driveline vibe after installing my 4inch springs, so I'll probably change my pinion angle while I'm at it. This should take care of the vibe :confused: right?
  19. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    thats what happend to my purches i got from summit, wrecked my driveshaft and yoke, so i made some out of 1/4 inch thick 2.5" box tubing
    the best way ive found to cut the old cast perches off was to cut around all the welds then beat them with a sledge hammer then grind the tube smooth, took a few minuets each side
