14b ff stock gearing
Discussion in 'The Garage' started by **DONOTDELETE**, Oct 10, 2002.
    I have a 14 B FF in my truck and need to know the stock gearing in it. Please help, I was told by the guy I bought the truck from the 14 B FF was stock.
    Thankyou for the help.
  1. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    there was prob around 4 choices for the 14bff...check the diff for id tags, pull the cover and count teeth or just turn the wheels and count the ratio of the drive shaft turning.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    "Stock gearing" can be 3.42, 3.73, 4.10, or 4.56.
    The only surefire way to find out exactly what you have is to pop the dif cover off and count the teeth on the ring and pinion.
    Or, look for some numbers stamped on the ring gear and divide them to get the ratio.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can add 3.21 and 5.13 to that list. /forums/images/graemlins/smirk.gif
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'll second the 3.21 with a matching 3.23 in the front.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the most common gear i am told is 4.10's but as others have stated, you have to pop the top and count the teeth, or the number is stamped on the gears.
  6. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Up here the most common ratio for the FF 14 is 3.73...must be a Canadian thing /forums/images/graemlins/angryfire.gif
    My buddy spent the last 3 months checking every set of 3/4 ton diff's advertised locally and the 3.73 sets were by far the most common.
    Rene
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Never heard of 3.21 and 5.13 is not stock. 5.13 is aftermarket. /forums/images/graemlins/wink.gif /forums/images/graemlins/smirk.gif
  8. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    both of mine were 3.73 /forums/images/graemlins/crazy.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The 3/4 ton axles I'm buying are 373 gears. /forums/images/graemlins/eek.gif
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    im in PA and the only ratio ive seen here at the jumkyards are 4.10 gears.like everyone said the easiest way is to pop the diff cover and turn the diff till you see the stamp on the ring gear.4.10 will have 41 10 stamped.3.73 will have 41 11 stamped on the ring gear.im pretty sure those were the most common.
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    5.13 Stock Gearing? Yeah right.
  12. Leadfoot
    Nov 28, 2000
    3,112
  13. u2slow
    May 9, 2001
    2,217
    BC Canada
    Re: 5.13's....
    Not in a SRW anyways - only in a 1-ton DRW (cab & chassis) with a 292 straight six. Fat chance in any other configuration.
    My old man has 3.21's in his '79 C20 crewcab. Despite the tall gearing, its never gone past 100km/h. (The eleven-foot camper won't let it!) /forums/images/graemlins/eek.gif
  14. Thanks guys for the help. I got 3.73 gears in my fron and rear edn. Now alls I need to do iss find me some 4.10 gears for my 14B FF rear and my 10 bolt GM front.
