14b FF swap
Discussion in 'The Garage' started by RustBuket, Oct 13, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well, I'm in the process of putting together some money for a 4" lift and tires and was just wondering about a 14bFF. I told my sister's bf about it and he said that you would probably have to change the master brake cylinder if you swapped the 1 ton axle in there because of the bigger brakes. I was just going to ask you guys what you thought about this idea. Did any of you guys have to do this? What is all involved? /forums/images/graemlins/1zhelp.gif
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    no need to swap the master cyl.it takes very little fluid to move the wheel cylinders.get one from a 73-87 3/4 ton,and it will bolt right in.i think with a one-ton rear,you will have to move the spring pads,i think.you will also need a conversion u-joint,and 8 lug wheels.shocks will bolt up,as will brake line.very easy swap.
  3. RustBuket
    Feb 21, 2003
    1,618
    Ok, thanks dude! Anything else? /forums/images/graemlins/ears.gif
  4. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    my uncle has a 14blt ff from a van, he said he would give it to me, i know i need to change spring perches and shock mounts. IS THERE ANYTHING ELSE I NEED TO DO, This is coming out of a 1ton dually van? /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  5. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i believe thats it.have fun! /forums/images/graemlins/thumb.gif van rears are a little wider than truck rears,but the swap is similar.you guys will also need the u-bolts from the 14 bolts,because there bigger.
  6. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, no need to mess with the master cyl when goin ff14b.. just hook up da brake lines 'n' drive.
    j
  7. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    one ton dually van?,if thats like a dually p/u rear,it will be narrower than a single rear wheel axle by a few inches.spring pads will still need to be moved.
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    The van width 14's will actually make the back tires stick out farther by about 2 inches on both sides than the front axle. As for the spring perches, they will have to be moved inward towards the differential. As to how much, I dont know.
    -Harrison
  9. RustBuket
    Feb 21, 2003
    1,618
