14B FF u-bolt size w/2.5" rear block........Anyone??
Discussion in 'The Garage' started by Mudbug1979, Oct 7, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    14B FF u-bolt size w/2.5\" rear block........Anyone??
    I am putting the ORD shackle flip on this weekend and installing a 2.5" rear block. I need new ubolts to go with this ,but I'm not sure about the size of the u-bolts. Anyone have any measurements so that I may order some and get them tommorow? No I don't have the old ones to measure, that would have been too easy.
  2. Mudbug1979
    Aug 4, 2002
    439
    Re: 14B FF u-bolt size w/2.5\" rear block........Anyone??
    All I need is the width and bolt size, the lenght I can figure out.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    5/8" x 3 3/8" x 10" should get you close.
    When I used to have 4" blocks I'd get my U bolts 12" tall, so with a 2.5" block, 10-12" should work great.
  4. Mudbug1979
    Aug 4, 2002
    439
    3-3/8 is the correct width right?
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes, the axle tube diameter on a 14BFF is 3-3/8". I am not sure if 10" from tip to tip os going to be long enough for you. My u-bolts are 10" long and you can see in the pic that there is just enough room to add a zero-rate if I so desired.
    Crappy pic:
    Measure how thick your springs are, add 3.375", the height of the perch, the thickness of the spring plate, about 1" for nuts and about 0.5" to stick past the nuts. Then add in the 2.5" for the block and see what you get. Then I might round up to the nearest whole inch just to be safe, but that is up to you. /forums/images/graemlins/waytogo.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just go 12". You can always cut them down.
