14b ff? Yeah another dumb ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5'er, Jan 13, 2002.
  1. k5'er
    k5'er Registered Member
    Nov 29, 2001
    92
    PA
    are all 14b's full floaters? if not, how can you tell? and i guess 14b is better than 12 bolt? sorry about the dumb questions.
    Mud! Its cool!
  2. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    nope there were 14 bolt ff and 14 bolot semi floaters.......the 14 bolt are stronger then a 12 bolt because of the size of the ring gear i think
    hola
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The 14 bolt full floats (C14FF) were much stronger than their semi-float counter parts. Ring is larger, pinion is larger and stronger with an extra bearing, axle shafts and housing are bigger and stronger (also heavier and less clearance). The C14FF is only available in 8 lug (custom can do 6) but the C14SF came in 6 or 8 lug.
    C14FF is easy to identify by the big hub sticking 4" or so out of the center of the wheel. C14SF look like a 12 bolt in the wheel. Also, the covers are different.
    <a target="_blank" href=http://coloradok5.com/axleguide.shtml>http://coloradok5.com/axleguide.shtml</a>
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. k5'er
    Nov 29, 2001
    92
    PA
    if it has the big hub sticking out, isnt that a 1 ton? and would that mean that a 14b sf is 3/4 ton?
    Mud! Its cool!
  5. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    The 14 SF and 14FF were both used in 3/4 tons. The one tons only got the 14FF. The 3/4 ton version of the 14ff generally had slightly smaller brakes and the spring perches are the same width as the 1/2 ton stuff. The one ton had the larger brakes and the perch width is different...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also the 1ton at least the later ones had the crossover e brake cable.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  7. k5'er
    Nov 29, 2001
    92
    PA
    hey wayne, i think ive seen ya before going through town. im in chambersburg. didnt realize you were in pa.
    Mud! Its cool!
  8. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    As far as i know the front pinion also unbolts on a 14ff, right?
    live to wheel, wheel to live--1972 gmc jimmy 8 inch lift, 37" ssr's
