14B FF Yoke seal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Sep 2, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'll be changing out the yoke on my 14 bolt (long story.) Is there a seal or gasket or something that I'll be needing to change? Is it a dealer kind of item or can I get it from Autozone?
    I just mark the nut and pinion shaft so I know how much to tighten the yoke nut on, right? ANything else?
    TIA
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The seal. And yes you can get it at Autozone. Shouldn't be more than 5-10 bucks at the most.
    tRustyk5 for President!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Much appreciated.
    -- Mike
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Check the yoke for a groove worn in it by the seal. If it can't be polished out using 1000+ grit sandpapers with a few passes (catches a fingernail when drawn across it), either replace it or get a Spedi-Sleeve (sp?) from NAPA before putting the new seal in. A groove will ruin a new seal prematurely.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
