14B FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skelly1, Dec 26, 2002.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    In the tech section on 14BB FF axle swap the following sentence is listed:
    "On newer Chevy's, the brake backing plate (picture H) will have to be changed to a press in style backing plate from a 14-bolt (SF) with 13" brakes."
    What does this mean? How much? Why? Part#? Brakes are then from SF, or are the brakes the same?
    There is also no mention of emergency brake cable.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Which article? I found like 3 that had something to do with the 14 bolt.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    This one
    As to answering your question.... /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif. Sorry I can't be of help yet. I'll be doing the swap this summer.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think it has to do with the different e-brake setup on the newer Chevs. not positive though...
  5. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    When does the "newer" years start? 87? Mine is a 90.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think it has to do with the body style. So it would depend on what you pulled the axle out of. Get one out of any 3/4 ton truck older than '88 and you should be fine.
  7. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Any other things that need to be changed? U-joint conversion and keep the U-bolt and spring plate from the FF?
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You'll need some u-bolts. The axle housing is larger. Would recommend getting new ones as they are not that expensive. Its a pretty straitforward swap.
  9. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Does the driveshaft need modification after this is done? Mine is still stock length, with the 1" spacers between the cross member and the frame to lower the rear of the transmission.
  10. heavy4x4
    Aug 28, 2002
    3,270
    No, driveshaft length should be fine. 10 bolt and 14 bolt yoke lengths bolt up to be about the same length. If there is a slight difference, it won't be significant enough to have to modify your driveshaft.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Are you planning on a suspension lift ??? Doing it at the same time as the axle swap is a good idea. Depending on how high you go will determen if any driveshaft mods are needed.
  12. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    I've got 4" lift springs already installed. They seem to be more like 3" or the fronts are 5" because it sits an inch or so higher in the front.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A set of add-a-leaf in the rear would fix that.
  14. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    What's that gonna cost me?
  15. heavy4x4
    Aug 28, 2002
    3,270
    Add-a-leafs will only work if he's got stock springs and blocks. If he has lift springs...he'd need custom add-a-leafs made. With lift springs...you'll have to go with ord's 1" zero-rate.
  16. heavy4x4
    Aug 28, 2002
    3,270
    Read above post about going add-a-leaf, or zero-rate. But, if you have blocks and a stock spring pack...add-a-leafs can be found for ~$50/pair.
  17. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    back to the original question, i think there's 2 syle E-Brake cables. You're 90 probably has the same type my 91 sub does (un-equal length cables that are 'push-in' style @ backing plate). My donor 14FF was from an 80 and had the 'looped' style cable (if i remember right??) and had a flange that bolted to the backing plate to secure it. I think you've got 4 options....
    1. E-brakes are optional equipment and forget they existed. (not recommended for all situations)
    2. convert to rear-disc brakes and using truck calipers see option 1.
    3. convert to rear-disc brakes and hunt down some late 70's Caddy elDorado calipers with the E-Brake hardware. The actuating lever is hard to find and doesn't come with re-mans as I understand it. Bring plenty of cash.
    4. Custom made cables. There's a few posts somewhere around that list some sources for them.
    Good luck on it! /forums/images/graemlins/smile.gif
  18. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    As far as the brake cables, you can take both style cables and mix and match the brackets to make work. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Do a search I know it's there. It works great, did this 6 month's ago, use my E-brake everyday and have had 0 probs. /forums/images/graemlins/thumb.gif
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    The year split between the backing plates for the e-brake cables is '82 and '83. /forums/images/graemlins/wink.gif
