14b front axle (old thread 2005)
Discussion in 'The Garage' started by K5MONSTERCHEV, Apr 3, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I finished my center diff 14 bolt front, except for shafts. /forums/images/graemlins/waytogo.gif
    14 bolt front
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Re: 14 BOLT FRONT AXLE
    That looks like the pinion is in the center how are you going to hook up a shaft?
    Thanks for emailing the pics to me!
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    crazy! /forums/images/graemlins/thumb.gif
  4. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, it sure is in the center. /forums/images/graemlins/thumb.gif
    Im going to clock the Tcase straight down for now. But later down the road im going bigger, and coilovers, with a custom center drop T case. Basically it'll be a little monster truck. /forums/images/graemlins/peace.gif
    OH, and im going to build another axle for rear steer! /forums/images/graemlins/waytogo.gif
  5. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    I can just see it now, 14 bolts 1500.00 & Dana 60 FRT. with a DL 250.00 OBO. Thanks /forums/images/graemlins/laugh.gif
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Woah, thats a nice truck, what year? How much clearence between the axles and ground? Good work /forums/images/graemlins/waytogo.gif
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Questions:
    1) What do you plan on doing for oiling for a "clocked straight down t-case"?
    2) Who are you having make your front inner shafts? Are you going to start with a Superior or Yukon blank and have it splined to the 30 sp. 45 degree pa for the 14 bolt or have something completely custom built?
    3) Why go with a 14 bolt center section? It has horrible ground clearance and not much of a strength advantage over a d60 center section.
    4) Are you going to shave it at all?
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    D60 outers?
  9. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    With that backwards like it is, won't you be pulling on the coast side of the teeth?
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hmmmmmmmmmm.... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif Interesting! /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  11. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    How about locker operation? I would think it would never lock? /forums/images/graemlins/dunno.gif
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    What are you doing for gears?
    Since you had to weld everything back together, why didn't you move the case to the driver's side so you could run a NP241HD or something? I don't see anything wrong with not having your transfer case output in line with the pinion shaft but I'm just wondering why you put it right in the middle.
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Cool... it looks like you put the frame on backwards when you built that rig /forums/images/graemlins/wink.gif I hope it works out well for you!
  14. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    dual land anchors? /forums/images/graemlins/confused.gif
  15. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    thats pretty freaken cool /forums/images/graemlins/waytogo.gif
  16. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Why not A D60,70,80? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    Bill
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    '72. 11 1/2" at the bottom of the diff.
    In answer to willyswanter:
    1. I plan on using a 241 for now until I get the center drop T case. The 241 has the oil pick up on the front output shaft side of the case, so that would be at the bottom, when clocked down.
    2. I was just going to have custom shafts made.
    3. I went with a 14 bolt because, why not? Its something different, everyone has a 60.
    4. No, im not going to shave it.
    Yes the outers are D60.
    I will be running on the Coast side, but since its a front axle, and not going to be drive on all the time it wont be that bad.
    As for a locker I was curious about that too. Itll be open for now, and if the locker doest work, I know how to weld!
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Its something I've thought of many times, but the only reason I would do a hybrid front axle would be to run a lightweight center section(say a 9") with the Dana 60 outers and some nice shafts. Like was noted, its really not gonna be much stronger, and since you are pushing the opposite way the gears are intended too I wouldn't be surprised at some big weakness there. Definetally something. If I were to do it you can bet that 14 bolt would have had a date with the milling machine and gained a good 2.5" of clearance.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Did you use some sort of jig to do your work?
  20. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The tube is the same inner diameter as 60 tube, but its 3/16" bigger diameter then 14b tube. I dont really care about ground clearance.
    No I had a company do it for me, VERY nice work.
