14b lockers, same for 4.10/4.56?
Discussion in 'The Garage' started by muddybuddy, Mar 22, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    buddy has a cucv 14b and ive got a stock 14b with 4.10s and a lockrite or some other locker. is it possible to swap the 4.10s onto the detroit from the cucv 14b and the 4.56's on the lockright or whatever locker? i know open carriers are different, so i dont think it will work, but i just want confirmation. thanks
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I'm pretty sure it can be done
    Aslong as neither are gove lock 14Bff you will be fine swaping between them.
    The only one that is diffrent it the govelock one.
  3. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I thought the breaking point was between 4:10 and 4:46. any gear ratio 4:10 and down are the same and any gear ratio 4:56 and up are the same
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thats what i thought, i just wanted verification
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    4.10 and down are the same and then 4.56 and up are the same. The only way to have 4.56 gears on the 4.10 carrier is to install 4.56 thick gears.
  6. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    If it's a lockrite or a detroit & it is in a 14BFF it will swap . You don't have to swap carriers for those lockers , they go inside of the carrier & replace the spider gears , but only if it is an open carrier.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    He is asking about swapping gears only, not carriers.
