14b SF swap questions
Discussion in 'The Garage' started by firefighter184, Feb 27, 2005.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Did a search, but after 1/2 hour of reading, couldnt find my answers.
    1) I know there are e-brake issues with swapping in a 14b FF, but what about the semi-float? I really want an e-brake.
    2) NAPA or other supplier part number for the longer rear brake line set-up?
    3) Looks like the SF will be able to re-use the u-bolts from my 10bolt. True? I'll probably get new ones, but I need to know which ones to get if I do.
    FINALLY getting the 3/4 ton done. I'm happy.:D
  2. dyeager535
    26,979
    1) Tough call. What year SF do you have? If it was a C/K one from about 1985-1987 (or 91 if burb I guess) then the cable setup should work on your '89, which is what we are dealing with, right? E-brake cable setup changed in about 1985, so anything earlier will have equal length brake lines coming off the backing plates..later are unequal because the "main" ebrake cable comes down the drivers side of the frame only.
    2) Someone else said that their 10 bolt lines bolted right up.
    3) Can't re-use the u-bolts. Bigger diameter axle tubes than a 10 bolt. 14FF and SF share same axle tube diameter though, so easy to find a donor in a wrecking yard if you have access. Might as well get spring plates at the same time, although the 10 bolt ones can be made to fit if the holes are opened up. 15/16" is what gets the u-bolts off on all the axles.
  3. CARL
    CARL Registered Member
    Apr 3, 2002
    14
    14 Bolt Swap
    Hi Firefighter...
    Why can't you use the rear end you want with the corresponding cables or have custom cables made. My dually has had a couple of rears changed over and I have not had any problems for using older cases and rebuilding the guts for less down time. Chevy always seems interchangeable for me.
  4. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I did this very swap into my 89 suburban.brake lines and ebrakes bolted right up,I did need the bigger u-bolts though.
  5. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    This is intereing here, I did a 14 bolt FF swap in an 82 Chevy 1/2 ton 4x4 Diesel, has a 10 bolt in it, and used the U bolts off the 10B when i installed the FF, anyone know if the diesel 10B was any different that others?
  6. dyeager535
    26,979
    No difference.
    All I know is that the 10 bolt axle tubes are smaller diameter than the 14SF and 14FF, and a *properly fitted* u-bolt cannot fit two different diameter axle tubes. Without getting fancy and re-bending, you'd have to pound the u-bolt over the thicker tube, and would end up with the two ends pointed out at an angle, not vertically like normal.
    Edit: 14SF/FF u-bolts are 4.75" from one tip of the "U" to the other, measured on the outside of the threaded portion. The 10 bolt measurement is 4.275". In other words, probably 1/2" difference in axle tube diameter/u-bolt size.
  7. big4x4ride
    Feb 11, 2004
    216
    Corpus Christi, TX
    Hmmm, wonder what the deal was then, becaus elike i say i used the u bolts anfd top plates off of the 10 bolt on the 14 bolt FF
  8. dyeager535
    26,979
    Apparently the later D44 and 12 bolt share the same axle tube diameter, 3", and the 10 bolt SHOULD BE the same. (couldn't find anything with *specifically* 10 bolt diameter mentioned though)
    The 14SF/FF use 3 3/8" tubes.
    LATE 10 bolt stuff might use larger tubes, since the center section changed somewhat, and the brake backing plate flange is now the same size/pattern as the newer 14FF's, and all 14SF's.
  9. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I put an '84 14sf in my '87 Blazer. The 10 bolt Ebrake cables installed into the 14sf backing plates no problem, some fiddling was necesary to the slack adjusters on the cables but it has worked fine for 2 years now. The ubolts from the 10 bolt did fit the 14sf, but they were part of the Tufcountry lift I had on at the time, didn't have to hammer or bend anything. Brake lines (hydraulic) were bolt in also. Only other thing was a Napa #447 conversion ujoint.
  10. Ledzoso
    Ledzoso Registered Member
    Feb 11, 2005
    15
    Midland, Tx
    Dont, know the answer to your question...just wanted to say hey to a fellow firefighter...PTB EGH
  11. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    What up smoke-eater?
