14b sf to 14b ff swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fireinthehole, Aug 12, 2003.
    When I find another 14b ff to put under my Sub, it should bolt right up to the stock u-joint right? I have a 3/4 ton Sub with the sf 14b now.
    Now I just need to find another one with 4.10's.
    Mat
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yepp it will bolt right in all you need in new u-bolts. the brake lines on my 3/4 ton sub hooked right up but my 14bff was older than my sub so the e-brake didnt work. /forums/images/graemlins/burb.gif
  2. Yeah, thats what I thought. The last time I did this swap it was 10b to 14b and the e-brake cable mount had to be fabbed up. So, do you have your e-brake hooked up yet?
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Make sure that 14 Bolt FF if off a 3/4 ton and not a 1 ton or you will need to relocate your shock mounts and spring pads. Also, pay attention to the parking brake set up, I found a set up that was compatible with my 91 Burb. There are several different parking brake set ups as they changed through the years. You should be able to find a 14 Bolt FF with a matching set up for your rig. It gets expensive to track down the correct parts after the install.
    Good Luck,
    Eric M.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    You may also have driveshaft length issues. I just swapped a 14BFF under my K20 in place of my 14BSF. The pinion snout on the 14BFF was 5" shorter than that of the 14BSF. Had to lengthen the driveshaft accordingly.
