14b spindle ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMC, Dec 11, 2002.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I just installed th 14b and had a leak at the wheel. I pulled the hub off and found the someone had punched the wheelbearing surface but they also put one punch mark on the seal surface. Do you think I could fill this in with epoxy and file it smooth to fix the leak? Any other ideas?
    /forums/images/graemlins/truck.gif
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Use a speedy sleve on the seal surface. This will be the easiest way to fix this correctly.
    Mike
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I second the speedi-sleeve install. Napa sells them for, if I remeber correcty, $40 or so? I gives the seal a new surface to ride on.
    I installed a speedi sleeve on both spindles of my 14B. I'll see if I can dig up the part number for you.
    Thomas.
    I just found the NAPA part #, it's: 'OIL SEAL P/N# 99282'
  4. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
