14b stcuk carrier,, detroit install.. a little help please
Discussion in 'The Garage' started by camiswelding, Jan 9, 2005.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    14b stuck carrier,, detroit install.. update
    see updated post
    please delete this one
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    I assume you removed the axle shafts first. If so it should pop right out after the caps are removed. If not you may have to go a few more turns on the adjusting nuts.
  3. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    removal info
    sorry to aks but did you remove the full floater shafts. and if so thay can sometimes need a good pop to get out.:cool1:
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Did you loosen up the big threaded things that are on either side of the carrier (sorry dont know what they are called) but they have a bunch of holes in them?? just make sure you count how many turns you made on them.
  5. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    axleshafts... I dont need no stinkin axles :). yes they are out... and were :)
    (cam is drooling now like a complete moron)
    the adjusting nuts.... how many turns are probably appropriate to get it loose... maybe I didnt make enough... they said 3 or 4?
    cam
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thats about the only thing that could hold it in there, maybe try and loosen it up some more and jiggle it. :)
  7. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    back to the shop... thanks guys... ok Ill try another turn or two
    cam
  8. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    the great news is that after some more turns it fell out in my hand... the bad news is twofold...
    I lost the count
    the magic marker came off and I lost the initial location for turn counts
    SOOOOOOOOOOOOO
    How can I properly setup the carrier again if I have lost the original specs???
    thanks
    cam
    (I wont make that mistaKE AGAIN)
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    When you reinstall the adjusting nuts just tighten down the main caps a little so you can turn the caps and reset the backlash. It is easy.
    I don't even ever count the turns when i do a 14FF or a 9" Furd. I always forget it anyway or i loose where i wrote it down.
  10. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks chief... Im already asking how to do that...
    cam
