14b swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cabledawg, Mar 27, 2007.
  1. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Ok I used the search and I think I have my answer. I have found an awesome deal on a set of 3/4 ton axles for my 1500 Burb. Same year as mine, 1990. According to what I have read, these axles should bolt right in if I get the springs with the axles. Am I correct, or is this going to be a PITA swap? Both my driveshafts are variable length, but how much longer is the nose on a 14b vs. a 10b? I didnt have time to get measurements when I was out there.
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    no need for the springs, Just make sure the 14 bolt is out of a 3/4 ton, and it will bolt in. and get the u bolt plates too.
  3. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    I've got a broken sping on mine right now, so will the 3/4T springs bolt in place of the 1/2T's?
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes they will and they might give you an inch lift since they are made or heavier trucks.:D
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If they are the same length yes.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Oh forgot, the newer 3/4 tons are 56" in the rear versus the 52 for the 1/2 tons.
    The front will bolt in, the rear maybe.
    :doah:
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    1/2 and 3/4ton 52's were used up to the late 70's IIRC, then they went to 56's
  8. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    I know I have 56" springs on mine, but like I said, I didnt measure the donor's. From what I can tell the width of the spring is the same, so if they are 56" long I assume the same frame brackets can be used.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep same width and same bracket
  10. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    You guys are AWESOME!
