14B Torque Spec?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigasschunk, Jan 10, 2003.
  1. bigasschunk
    bigasschunk Registered Member
    Jul 30, 2002
    14
    Alabama
    I did a search but couldn't find it...... so does anyone know the torque spec for the bolts that connect the two halves of the carrier? I'm putting a detroit locker in my 14B FF and replacing a Gov. Lock. Anything special I need to watch out for. I've worked on a lot of D60s but this is my maiden voyage on a 14B. /forums/images/graemlins/1zhelp.gif
    Thanks,
    Kevin
  2. NoShow84
    NoShow84 Registered Member
    Aug 23, 2001
    35
    KANSAS
    when i did my locker i didn't know the torque spec, so i called 4 wheel parts and they told me what they were. whish i could remember myself. as far as anything special not that i know of just make sure that you bolt the carrier back together before removing the bolt and washers that are going though the middle of the detroit.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The ring gear bolts hold the two halves of the carrier together, and the torque spec is 120 lb-ft.
  4. bigasschunk
    Jul 30, 2002
    14
    Alabama
    Thanks man, /forums/images/graemlins/thumb.gif
    Kevin
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    In case you don't know, a detroit will not fit a gov-loc carrier, you must have an open carrier to install a detroit.
